Normal Topic IncomingArrows   (Read 5220 times)
lemon
IncomingArrows
Aug 31st, 2005 at 11:50am
If I liked to store a new box, I need the parent node ID(box id).
I like to use for it the attribute IncomingArrows  however I find not the characteristic of IncomingArrows, which stores the contal ID of the superordinate node.
Thx for help
Re: IncomingArrows
Reply #1 - Aug 31st, 2005 at 11:59am
If I understand correctly, from one box you need to get its neighbor boxes linked to the other end of incoming arrows. Use the arrows' OriginBox and DestinationBox properties to do that. E.g.
for each link in theBox.IncomingArrows
  dim otherEnd as box
  set otherEnd = link.OriginBox
next link
Or to find the boxes connected through box' OutgoingArrows:
for each link in theBox.OutgoingArrows
  dim otherEnd as box
  set otherEnd = link.DestinationBox
next link
I hope this helps.
Re: IncomingArrows
Reply #2 - Aug 31st, 2005 at 12:01pm
So supposing you store the IDs in the box.Tag property, you can access them like:
  dim otherEnd as box
  dim id as integer
  id = otherEnd.Tag
next link
lemon
Re: IncomingArrows
Reply #3 - Aug 31st, 2005 at 12:14pm
Sorry I have no .OriginBox only
.OrignIndex,
.OrignAnchor,
.Origin
foreach(Arrow a in b.IncomingArrows)
  Box ParentBox;
  ParentBox = a.xyz; //?
  b.Parent = ParentBox.Tag;
lemon
Re: IncomingArrows
Reply #4 - Aug 31st, 2005 at 12:28pm
sorry wrong code
  Box ParentBox;
  ParentBox = a.  ??? ;
  b.Tag = ParentBox.Tag +"|"+ b.Tag;
Re: IncomingArrows
Reply #5 - Aug 31st, 2005 at 12:34pm
It seems you are talking about FlowChart.NET and not about FlowChartX, right ? Then use the Origin and Destination properties of arrows.
