Normal Topic can't find my listBoxes on my flowChart (Read 6156 times)
lemon
Sep 8th, 2005 at 7:19am
Hallo,
to each node I provide a listBox. how can I all listBox-Controlls address at one time.
I can't add a listBox to my flowChart-Controll. How can I get my listBox-Object IDs?
tnx for support
Re: can't find my listBoxes on my flowChart
Reply #1 - Sep 8th, 2005 at 7:37am
Just how do you provide a ListBox to each node ? Do you mean you have ListBoxes hosted in ControlHost nodes ? If so, use the ControlHost's Control property to access the embedded .NET controls.
Sorry if I haven't understood your question correctly.
lemon
Reply #2 - Sep 8th, 2005 at 8:02am
many more simply!
during I provide a new box. I provide a listBox controll, too
like this:
InfoBox = new ListBox();
InfoBox.Items.Add(box.Text);
InfoBox.Location = new System.Drawing.Point((int)box.BoundingRect.X+15, (int)box.BoundingRect.Y);
InfoBox.BringToFront();
No more.
I will create a methode how can change a InfoBox attribute. For this I must find all my created InfoBoxes. But how???
Reply #3 - Sep 8th, 2005 at 8:45am
You mean you create the ListBoxes inside the form and display them over the FlowChart ? Then you can access them via the form's Controls collection which contains all its child controls. You might also store a reference to the ListBox in its associated box' Tag property, or just the listbox' index within the form's Controls collection.
I hope that helps.
lemon
Reply #4 - Sep 8th, 2005 at 8:48am
this works thanks
foreach (Control c in this.Controls)
if (c is ListBox)
((ListBox) c).Visible = true;
