Normal Topic x/y-points (Read 4041 times)
lemon
x/y-points
Sep 8th, 2005 at 9:18am
next question  Smiley
I get my x and y points from a database.
like
float x=node.X;->175,48
float y=node.Y;-> 125,08
Box b = _flowChart.CreateBox(x, y, 15, 15);
If I take the same worths for my listBoxes. the controlls have other worth. how can it be?
like
listBox.Top = (int)b.BoundingRect.Top;->4,2
listBox.Left = (int)b.BoundingRect.Left;->62,44
on this way the position for the listBoxes are not the same like the nodes
where is the error?
Re: x/y-points
Reply #1 - Sep 8th, 2005 at 9:45am
By default FlowChart.NET measures stuff in millimeters, as set in the MeasureUnit property. So you can either set MeasureUnit to Pixels or use the flowchart's DocToClient method to convert the box coordinates to form coordinates.
