Normal Topic How to do a full overview of the whole flowchart (Read 4460 times)
mah
Guest
Sep 15th, 2005 at 5:31am
I am wonder how we can do the overview of the flowchart on a floating form in vb.net (like in the demo)
do you have the sample code?
Re: How to do a full overview of the whole flowcha
Reply #1 - Sep 15th, 2005 at 6:53am
You just create a new form OverviewForm in your project and place the Overview control in it. Set the overview's Dock property to Fill and FitAll to true.
Add such method to the new form:
public sub SetDocument(doc as MindFusion.FlowChartX.FlowChart)
overview1.Document = doc
end sub
And somewhere in the main form show the overview form like this:
ovForm = new OverviewForm()
ovForm.SetDocument(flowChart1)
ovForm.Owner = Me
ovForm.Show()
mah
Guest
Reply #2 - Sep 20th, 2005 at 6:08am
i have error on this
below is my codes.
Imports MindFusion.FlowChartX
Imports WindowsApplication1.Form1
Public Class overview
    Private Sub overview_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
       Dim ovForm = New overview()
       ovForm.SetDocument(Form1.FlowChart1)
       ovForm.Owner = Me
       ovForm.Show()
    End Sub
    Public Sub setDocument(ByVal doc As MindFusion.FlowChartX.FlowChart)
       Form1.FlowChart1.Dock = DockStyle.Fill
       overview1.document = doc
    End Sub
End Class
Reply #3 - Sep 20th, 2005 at 6:52am
Is that a compiler error? Is the Overview instance in your form called 'overview1' so the
assigment is correct ?
mah
Guest
Reply #4 - Sep 20th, 2005 at 7:25am
dun worry, i forget to add the overview component.
and forget to do the overview form.. i settle my problem.. thx a lot..
