Normal Topic Why the unexplained MIT connection ? (Read 4615 times)
Mike M
Guest
Sep 18th, 2005 at 8:49am
My firewall intecepted outbound traffic when I loaded this software.
Why does the XML viewer try to connect to MIT and another server in France when it loads ?
There may have been other connection attempts - I just terminated the application at this point.
Re: Why the unexplained MIT connection ?
Reply #1 - Sep 19th, 2005 at 4:25am
Probably there is an external DTD or schema file on the MIT server referenced by the XML document you were trying to view, so the XML Viewer tries to download that schema. Otherwise, XML Viewer wouldn't ever try to connect to any server on its own whim.
