Normal Topic Mouse over event for Boxes and arrows (Read 4559 times)
isaac.contreras-pu
Sep 19th, 2005 at 10:16pm
Hello.
My question is:
How can I generate an event when the mouse is over a box or arrow?
I'm almost sure that this is possible, but I havent found the event that could do this.
Regards.
Re: Mouse over event for Boxes and arrows
Reply #1 - Sep 20th, 2005 at 7:14am
You can use the MouseMove event to detect that:
private void fc_MouseMove(object sender, System.Windows.Forms.MouseEventArgs e)
Point clientPt = new Point(e.X, e.Y);
PointF docPt = fc.ClientToDoc(clientPt);
Box b = fc.GetBoxAt(docPt);
suwit
Guest
Reply #2 - Sep 25th, 2005 at 3:01pm
Any solution to detect Row Index of the table object when mouse down event raised on that table ?
Reply #3 - Sep 25th, 2005 at 6:19pm
There is a TableCellClicked event raised when a cell is clicked; use its Row argument to detect clicks on a table row.
suwit
Guest
Reply #4 - Sep 26th, 2005 at 4:16pm
Thanks, but my project needed to detect row index while mouse move over that Table. Is it prosible to do this?
Reply #5 - Sep 26th, 2005 at 5:05pm
There is an internal method of the table to return a row index by point coordinates, so we can make this public in next release. Till then you can use this part of the code to find the row index:
float h = Math.Min(rect.Top, rect.Bottom) + captionHeight;
float w = Math.Min(rect.Left, rect.Right);
if (pt.Y < h) return false;
row = 0;
col = columnsCount - 1;
Row r;
int i;
for (i = currScrollRow; i < rowsCount; ++i)
r = (Row)rowsList[i];
if (pt.Y >= h && pt.Y < h + r.Height)
row = i;
break;
h += r.Height;
if (i == rowsCount) return false;
The 'rect' above is table's BoundingRect, rowsList is the table's Rows and rowsCount is the tables's Rows.Count.
