Normal Topic Moving groups (Read 5422 times)
Jon Merrifield
Guest
Moving groups
Sep 19th, 2005 at 8:07am
Is it possible to set up a group so that moving a subordinate node moves the whole group?  I need to create a group of nodes which cannot be separated from each other, and I don't really want to disable moving the subordinate nodes.
Jon
Re: Moving groups
Reply #1 - Sep 19th, 2005 at 8:18am
You could try the following:
1) Create a Transparent box in the background (set its ZIndex to 0)
2) Assign to its BoundingRect the union of all subordinate nodes rectangles + the current master node
3) Group all nodes to it, including the node you currently use as a master
4) Lock all subordinated nodes
Now if you click on any of the subordinated nodes, the invisible master node will be selected and moving it will move all attached items.
suwit
Guest
Re: Moving groups
Reply #2 - Sep 26th, 2005 at 4:22pm
Hello, can u show me a sample project.
Re: Moving groups
Reply #3 - Sep 26th, 2005 at 5:24pm
This one creates a group of nodes like the described above:
https://mindfusion.org/_beta/Switch.zip
It's in VB.NET; you can create the group by double clicking.
