Normal Topic Chart brushes (Read 7188 times)
Yannil
Chart brushes
Sep 22nd, 2005 at 9:56am
Even when I set the multicolored property to true my chart is not drawn in one color. Any suggestions why?
Iva
Re: Chart brushes
Reply #1 - Sep 23rd, 2005 at 9:45am
Check the number of Brush - es you have in the ChartBrushes array. If it is just one all chart graphics shall be drawn with it no matter MultiColored is set to true.
Warren
Re: Chart brushes
Reply #2 - Sep 27th, 2005 at 5:23am
I add a few brushes but I do not see any chart parts drawn  with them? I have multicolored set to true, but somehow no chart part is drawn with any of my brushes.
Iva
Re: Chart brushes
Reply #3 - Sep 28th, 2005 at 8:14am
Did you clear the predefined brushes? When any MasterChart control is dragged at the VisualStudio Form Designer the sample chart is drawn with a set of several Brush-es, which you should clear first so that only yours could be used.
Warren
Re: Chart brushes
Reply #4 - Sep 29th, 2005 at 8:37am
It works o.k. now, 10x. Are these brushes used for drawing the labels at the axes?
Iva
Re: Chart brushes
Reply #5 - Sep 30th, 2005 at 10:45am
ChartBrushes are used when the MultiColoredLabels property is set to true. Then every row/column of labels is drawn with the corresponding ChartBrushes - object. Otherwise the LabelBrush is used.
Yannil
Re: Chart brushes
Reply #6 - Oct 3rd, 2005 at 10:53am
When I draw a line graphics with some figures in it the figures are drawn in different color each time, but not the color of the line. How can I draw both of them in a single color?
Iva
Re: Chart brushes
Reply #7 - Oct 5th, 2005 at 7:54am
The shapes at line charts are drawn with brushes from the PointShapeBrushes property. The lines are drawn with pens as set by ChartPens.
