Normal Topic Zoom out problem (Read 2355 times)
davidw
Zoom out problem
Sep 28th, 2005 at 3:13pm
When ZoomFactor is very small, I cant draw or moveboxes in the area at the right of the chart. The control just displays a crossed out circle. Why should that happen?
TIA
Re: Zoom out problem
Reply #1 - Sep 28th, 2005 at 4:41pm
Try increasing the diagram area size using SetDocSize or set AutoSizeDoc = true. You could also enable users drag items outside the defined document area with one of the values of RestrictObjsToDoc.
