Normal Topic Trouble with tooltips (Read 2961 times)
sbailey
Jun 4th, 2009 at 7:30pm
I'm calling PutShowToolTips( true ) on the newly created flowchart instance, then creating a table and doing the following:
spTableItem->PutToolTip( tooltipstring );
spTableItem->PutCellToolTip( 0, 0, tooltipstring );
but hovering neither over the caption nor the cell triggers a tooltip... I just see the hand cursor. Is there a step I'm missing?
Editor Programmer&&Bethesda Softworks
Re: Trouble with tooltips
Reply #1 - Jun 4th, 2009 at 7:54pm
Perhaps something in the application initialization code destroys the flowchart's tooltip window. What happens if you call PutShowToolTips(false) followed by PutShowToolTips(true) from some button click handler?
sbailey
Reply #2 - Jun 4th, 2009 at 8:04pm
Calling it right before I set the tooltip text worked... thanks!
