Hot Topic (More than 10 Replies) Dropping boxes on other boxes (Read 11370 times)
Pascal
Re: Dropping boxes on other boxes
Reply #15 - Oct 8th, 2005 at 7:42pm
Hi all,
I interrested in this modification too. I've implemented the drag and drop but now I have the same refresh problem.
Is it possible to have this modification too.
Thanks.
Pascal.
Reply #16 - Oct 10th, 2005 at 9:47am
I've just emailed the updated dlls to both of you; let me know if you face any problems with the new method.
Jon Merrifield
Guest
Reply #17 - Oct 10th, 2005 at 10:05am
Stoyo,
We had a discussion a while back (http://mindfusion.org/cgi/Forum/YaBB.pl?board=fcnet_disc;action=display;num=1127...) about grouping boxes using a transparent background box.  I'm trying to combine these two features now and running into some difficulty.  If I set up a group of boxes which are subordinate to a transparent background box, and then try and drag that group onto another box, I can't seem to get a reference to the 'drop target' box underneath, the code I had been using will only return the background box.  This occurs even though I use GetNodeObjectAt with ExcludeLocked and ExcludeSelected set to True, and the background box is the currently selected box.  Have you any ideas how I can make this work?  Thanks,
Jon
PS Thank you for the daily build file - just received it
Reply #18 - Oct 10th, 2005 at 11:26am
Jon,
Are you sure that the returned object is the transparent master box ? If the subordinated objects are not locked, some of them might be returned by GetNode.
Jon Merrifield
Guest
Reply #19 - Oct 10th, 2005 at 12:04pm
Stoyo,
Done some further checking and the box returned is actually the backbox of the 'drop target' rather than the box about to be dropped.  That's exactly what I would expect, I had just forgotten that I was dropping onto one of these groups as well!
The updated dll works very well, thanks for that.
Jon
Pascal
Reply #20 - Oct 11th, 2005 at 11:00am
The new dll's working fine.
Good job guys.
Pascal.
Tati
Reply #21 - Feb 13th, 2006 at 6:23pm
Stoyo wrote on Oct 6th, 2005 at 10:17am:
Ok we often get requests for handling 'drag over box/table' operations, I'll get a developer here implement some events for these in the next release of FlowChart.NET.
Hi,  I am evaluationg 4.0.2 version and am wondering if there are new events to drop a box over another?
Thanks!
Reply #22 - Feb 13th, 2006 at 6:47pm
There is only the BoxModified event raised when a box is moved and dropped somewhere. Then you can detect if there are other boxes at that position by iterating the Boxes collection and calling the
public bool Intersects(Node node)
method.
