Normal Topic XML viewer saves empty files (Read 6695 times)
Bart Kaptein
Guest
Oct 10th, 2005 at 10:46am
I installed XML-Viewer 2.21 on my new laptop. XML viewer seems to work OK, but when I save the file, I get an empty (0 bytes) file on my drive  Embarrassed.
Greetings,
Bart.
Re: XML viewer saves empty files
Reply #1 - Oct 10th, 2005 at 11:08am
Thank you for letting us know about that. Would you be so kind to email to our support address the XML file you loaded initially ?
Thank you
Reply #2 - Oct 11th, 2005 at 2:32pm
Thanks for the file. Tomorrow I'll investigate what might go wrong.
Reply #3 - Oct 12th, 2005 at 6:13am
The bug is fixed, you can get the patched exe from the link below:
https://mindfusion.eu/XMLViewer.zip
