Normal Topic File not saving correctly (Read 9023 times)
Jeff Hartman
Guest
Oct 11th, 2005 at 12:54pm
I have been using the XML viewer to successfully view my files.  I recently tried using it to add nodes and attributes.  Everything seems fine until I try to save the file.  It appears to save the file correctly, but the file then goes to 0 bytes in size and when I try to reopen it, all the data is gone.  I tried both Save and Save As with the same result.
Jeff Hartman
Guest
Re: File not saving correctly
Reply #1 - Oct 11th, 2005 at 12:58pm
Sorry, this was meant to be posted on the XML Viewer bug reporter.  I see on that location that someone else already reported this same problem.
Jeff
Reply #2 - Oct 11th, 2005 at 2:35pm
Thank you too for sending me a file. I'll try to fix that tomorrow.
Reply #3 - Oct 12th, 2005 at 6:15am
The bug is fixed, you can get the patched exe from the link below:
https://mindfusion.eu/XMLViewer.zip
bkaga222
Reply #4 - Nov 21st, 2005 at 8:09pm
Hello, the link with the fix posted here points to version 2.3, the issue with saving 0 byte files is ocurring in this version as well. Could you please post a new fix.
Reply #5 - Nov 22nd, 2005 at 6:20am
How did you manage to save a 0 byte file? I cannot reproduce that with the 2.3 version. Could you e-mail me a file that won't save correctly after loading and modifying it ?
Thank you
Reply #6 - Nov 23rd, 2005 at 11:24am
Thank you, indeed that happenned because of the '&' characters. This version should fix it:
