Normal Topic Doubts in FlowChartX Professional (Read 3025 times)
Rafael Ambrosini
Guest
Oct 17th, 2005 at 12:01pm
Hello!
I work in a software manufacturer (SoftExpert – www.softexpert.com) and we need to change our current flowchart component in our process mapping system. We checked the On-line Demo for the FlowChartX Pro component and installed the trial version to test your product and it proved to be very helpful and a user-friendly interface.
However, for our purchasing FlowChartX Professional, we would like to clear up 2 doubts:
1 – We couldn’t view a web example which has a Container Box. We saw, through Trial FlowChartX Pro Examples that is possible to group items in containers, however, we couldn’t testity it in the Web version. We tried to make a HTML example page inserting a Container Box but the available component doesn’t allow this, just in the Professional version. Is there a way we could view Container Boxex on the Web, instead of using the Standard path (http://www.mind-fusion.com/fcx_std_30x_trial.CAB), could we use the Professional path temporarily?
2 – We checked the end-of-line break in the text inside the flowchart boxes and it wasn’t displayed correctly. Currently, when we put a text with line-break it displayed some strange characters instead of the line-break. Has this problem been solved?
Thank you for your kind attention and we await for your reply.
Sincerely yours,
Rafael Ambrosini
System Analysis
SoftExpert Quality Software
http://www.softexpert.com
Re: Doubts in FlowChartX Professional
Reply #1 - Oct 17th, 2005 at 12:38pm
Hi!
Here is a freshly built CAB for FlowChartX Pro:
http://www.mind-fusion.com/fcx_pro_trial.CAB
The Pro version CLSID is
{F025BF4E-4081-4c02-86E6-6602AEE846F6}
Re text breaks, make sure you use a multi-line TextStyle for boxes, e.g. any style whose ID  finishes in "ML" or any of the "fit to polygon" styles.
Sincerely,
  MindFusion
