Normal Topic Using Hyperlink (Read 2523 times)
Ashish
Guest
Using Hyperlink
Oct 17th, 2005 at 7:59pm
Hi
I use this code to create a hyperlink
objBox.Hyperlink = "http://ebrp.net"
The box style is ellipse
and I have set it's text property to some text.
It does not work.
Do I need to write some more code.
DO we have an example on this.
Re: Using Hyperlink
Reply #1 - Oct 18th, 2005 at 3:36am
Hi
Setting the Hyperlink does not change the box shape. That property is used by the HtmlBuilder class to create image maps by assigning the hyperlink to the HREF attributes of the map AREA tags. Otherwise, clicking on a box in the flowchart that has a hyperlink assigned won't automatically navigate an OBJECT-containing browser to that hyperlink. You could handle the BoxClicked event and open the hyperlink with some java code.
