Normal Topic Automatic remove child node. (Read 5567 times)
suwit
Guest
Oct 31st, 2005 at 1:11pm
How to automatic copy/Remove child node. when parent has copied/remove. ???
Iva
Re: Automatic remove child node.
Reply #1 - Oct 31st, 2005 at 1:39pm
What do you mean by 'child node' ? Is that a child node in a tree or an attached/subordinated node in a group ?
suwit
Guest
Reply #2 - Oct 31st, 2005 at 3:08pm
Pls check it in a Flowchart.NET Demo project
-> Item of "Miscellaneous Feature" sample.
i want to remove "Belin" and it should be automatically remove the node "1km".
Like cardcade delete.
Swt
suwit
Guest
Reply #3 - Oct 31st, 2005 at 3:13pm
Same problem in sample "Network sample"
when i removed node "Desktop Computer" icon why node's description not remove together.
Iva
Reply #4 - Oct 31st, 2005 at 4:03pm
Set the Group object's AutoDeleteItems to true. That makes the subordinated items in a group deleted when the group master is deleted.
suwit
Guest
Reply #5 - Nov 1st, 2005 at 3:51pm
thanks, it's work!
and one question, how about copy Group object ? is it posible to do like delete ?
Swt.
Iva
Reply #6 - Nov 1st, 2005 at 4:16pm
Is that about copying to the clipboard? Unfortunately there isn't any similar property to let you copy groups to the clipboard.
Still it might be easy to implement that like this: Before calling PasteFromClipboard, remember in a variable the size of the fc.Objects collection. After calling the Paste method, do a cycle on fc.Objects starting from the saved size and running to the end of the collection. The iterated objects would be all the pasted ones. For each object that should have a group, just recreate its group.
That would work fine if the child objects are just some UI elements or decorations, as in the 1st screen that shows tables and groups in the FCDemo sample.
Regards
suwit
Guest
Reply #7 - Nov 2nd, 2005 at 1:14am
could u pls show me a sample code to implement this.
Reply #8 - Nov 2nd, 2005 at 8:48am
Say you have a method createDecorations(Table) that creates and groups some UI boxes to a table. Then you could implement pasting like that:
[code]
private void paste_Click(object sender, System.EventArgs e)
  int oldItemCount = fc.Objects.Count;
  fc.PasteFromClipboard(0, 0);
  for (int i = oldItemCount; i < fc.Objects.Count; ++i)
    Table table = fc.Objects[i] as Table;
    if (table != null)
     createDecorations(table);
[/code]
