Normal Topic Custom Arrow type (Read 1593 times)
tivadj
Custom Arrow type
Dec 23rd, 2005 at 8:53am
Hello.
I want a user to create an arrow of my class during interaction process (Behaviour.CreateArrow etc.)
How can I implement it?
Thanks.
Re: Custom Arrow type
Reply #1 - Dec 23rd, 2005 at 9:17am
Try creating a custom Behavior class and return an instance of your arrow class from the StartDraw method. Assign the behavior object to flowhchart.CustomBehavior.
Below you can see how the CreateArrowBehavior class is implemented, change it so it creates new YourArrowClass instances instead of new Arrow instances:
[code]
public override InteractionState StartDraw(PointF pt)
  ChartObject ac = fc.ActiveObject;
  Node obj = fc.GetNodeAt(pt);
  int handle = 0;
  if (ac != null && !ac.notInteractive() && ac.pointInHandle(pt, ref handle))
    return new InteractionState(ac, handle, Action.Modify);
  else
  if (obj != null && obj.canHaveArrows(true))
new Arrow(fc, obj), -1, Action.Create);
  else
  if (obj == null && fc.AllowUnconnectedArrows)
new Arrow(fc, fc.Dummy), -1, Action.Create);
  else
fc.Selection, -1, Action.Create);
[/code]
