Normal Topic Avoid boxes or ControlHosts from overlapping? (Read 2636 times)
Sushant Raut
Guest
Jan 4th, 2006 at 11:49am
I want to have functionality like this:- I want to avoid overlapping of Nodes(Boxes and ControlHosts) while dragging or Moving in Flow Chart .NET
Re: Avoid boxes or ControlHosts from overlapping?
Reply #1 - Jan 4th, 2006 at 12:05pm
You could handle the BoxModified and ControlHostModified events and change the dropped node location if it overlaps another node. Use the Node.Intersects to determine whether two nodes intersect. It is up to you to choose where to place a node if it was dropped over another one.
Sushant Raut
Guest
Reply #2 - Jan 5th, 2006 at 3:07am
Thanks stoyo. I thought about this solution but I want some good interface. while dragging node  itself user should recognise that on this place he can not drop perticular node.
Reply #3 - Jan 5th, 2006 at 7:12am
You might change the mouse cursor icon from the *Modifying event handlers to show that a node cannot be dropped at a particular location. Just set the FlowChart.Cursor property.
