Normal Topic Zoom factors collision with moving Control host (Read 1885 times)
Sushant Raut
Guest
Jan 9th, 2006 at 9:51am
I am handling control host moving with mouse drag. It is Obvious I need to calculate mouse position according to Flowchart control and then moving perticular control host at the new point. But this looks good when zoom factor is normal. But when zoom factor changes ... then control host does not move with mouse pointer. To avoid this I have to do something like
new position = old position / (zoomfactor/100)
but this is cumbersome ??? that we need to handle it programmatically. Please tell me, Is there any method to avoid this?
Re: Zoom factors collision with moving Control hos
Reply #1 - Jan 9th, 2006 at 9:59am
You could use these methods to convert from mouse to document coordinates considering the scroll and zoom values:
RectangleF ClientToDoc(Rectangle clientRect);
Rectangle DocToClient (RectangleF docRect);
If your control does not capture the mouse input and depending on the value of HostMouseAction, the flowchart could be able to capture the mouse and handle the dragging of control hosts itself.
Sushant Raut
Guest
Reply #2 - Jan 10th, 2006 at 5:26am
Thanx...
