Normal Topic how to add my property to Appintment (Read 6128 times)
hsun
Jan 24th, 2006 at 1:28pm
planner.NET looks nice, but how I add my own property to Appointment? I need two my data in the Appointment class.
TQ
Re: how to add my property to Appintment
Reply #1 - Jan 24th, 2006 at 2:01pm
In order to add custom data to an appointment, you need to create your own class derived from Appointment. You can add whatever additional properties you need to the derived class.
The sample below demonstrates how to do this.
class MyAppointment : Appointment
  public MyAppointment()
    customData = 5;
  public int CustomData
    get { return customData; }
    set { customData = value; }
  private int customData;
Use the Calendar.InteractiveItemType property to specify that items from your class should be instantiated whenever the user creates items interactively. In this case you have to ensure that your class provides parameterless constructor as stated in the Planner.NET documentation.
I hope that helps
hsun
Reply #2 - Jan 25th, 2006 at 4:03pm
thank man. I try it ...
hsun
Reply #3 - Jan 25th, 2006 at 5:39pm
my data is not saved in the file, what I should to to save my own property in the method SaveTo of Schedule ?
Thank You
Reply #4 - Jan 25th, 2006 at 6:21pm
To enable serialization of your custom items, register the item class for serialization by calling "Schedule.RegisterItemClass". Override the SaveTo and LoadFrom methods of the Appointment class and perform the necessary serialization/deserialization of the custom data there. Call the base class SaveTo and LoadFrom methods from your overrides so the Appointment class can serialize/deserialize its standard properties.
