Normal Topic Overlapping arrows (Read 1586 times)
mark
Overlapping arrows
Jan 27th, 2006 at 1:40pm
Hi
I'm programmatically building up a flowchart and occasionally I end up with two different arrows connecting the same two nodes. When I do a layered layout the 2 arrows overlap so I can only see the top one. Is there any way of forcing them two route apart from each other?
Re: Overlapping arrows
Reply #1 - Jan 27th, 2006 at 3:20pm
At this time the LayeredLayout cannot handle such arrows automatically. You could set them apart by assigning an AnchorPattern to the nodes and explicitly setting the anchor points to which the arrows connect. Then run the layout with its Anchoring proprty set to 'Keep'.
