Normal Topic Reminder trouble (Read 4400 times)
AndreaBaro
Reminder trouble
Jan 31st, 2006 at 8:02pm
Hi !
I'm using Planner.NET rel 2.0 whit italian settings:
if i create an appointmnet and set remainder object, at specified time it doesn't work !
i've set message, time=appo.starttime and type=exact: i forgot something ?
best regards
Andrea
p.s.) also demo project doesn't work for me !
Re: Reminder trouble
Reply #1 - Feb 1st, 2006 at 7:49am
Hi!
What do you mean by 'demo project does not work', is it about reminders not showing ?
Reminders in Planner.NET raise an event. In order to be notified for a reminder, you must handle Schedule.ItemReminderTriggered.
Assuming that the variable 'calendar' references a Planner.NET calendar control, the code below shows how to the event could be handled:
calendar.Schedule.ItemReminderTriggered +=
  new MindFusion.Scheduling.ItemEventHandler(OnItemReminder);
private void OnItemReminder(object sender, MindFusion.Scheduling.ItemEventArgs e)
  MessageBox.Show(e.Item.Reminder.Message);
AndreaBaro
Reply #2 - Feb 1st, 2006 at 9:29am
ok !
I've misunderstood reminder's instructions....
now it's work fine ....
thank you !
