Normal Topic Problems building a large tree of boxes (Read 2508 times)
Anand
Guest
Feb 3rd, 2006 at 1:42pm
Hi I am building a very large tree (about 320 nodes and 321 arrows between the nodes). The Flowchart.NET control seems to go belly up when I try this. Here are the problems I am seeing when I build the tree with a layout TopToBottom
The Horizontal scrollbar fails to show up. The vertical is the only one that shows. How can I make the horizontal scrollbar show? If I try zoomtofit I can see all the nodes in there but it doesnt let me scroll in normal view and look at all my nodes. here is my code I tried both with grouping and without grouping as you can see in the code. How can I fix this?
private void GenerateTree(Customer rc)
ArrayList al = rc.NetworkAsTree;
foreach(NodeData nd in al)
RootNode = CreateBox(nd.Node.Name);
//AssessmentTree.CreateGroup(RootNode);
GenerateNodes(RootNode, nd);
Rearrange();
AssessmentTree.RouteAllArrows();
private void GenerateNodes(Box Parent, NodeData nd)
foreach(NodeData nd1 in nd.Children)
Box b = AssessmentTree.FindBox(nd1.Node.Name);
if (b == null)
b = CreateBox(nd1.Node.Name);
//Group parentGroup = AssessmentTree.FindGroup(Parent.Tag);
//parentGroup.AttachToCorner(b, 0);
//AssessmentTree.CreateGroup(b);
AssessmentTree.CreateArrow(Parent, b);
Rearrange();
GenerateNodes(b, nd1);
private Box CreateBox(string Text)
Box b = AssessmentTree.CreateBox(0,0,30,10);
b.Text = Text;
b.Tag = Text;
return b;
private void Rearrange()
if (treeLayout == null)
treeLayout = new TreeLayout(RootNode,
TreeLayoutType.Cascading,
false,
TreeLayoutArrowType.Straight,
TreeLayoutDirection.TopToBottom,
10, 5, true, 10, 10);
treeLayout.Arrange(AssessmentTree);
Re: Problems building a large tree of boxes
Reply #1 - Feb 3rd, 2006 at 1:56pm
Creating or moving items programmatically won't resize automatically the document scrollable area. Try setting larger DocExtents or call the FitDocToObjects method after building the tree.
