Normal Topic Invalid Cast (Read 2801 times)
Stuart Maher
Guest
Invalid Cast
Feb 16th, 2006 at 1:50pm
I've downloaded the trial version and looked through the demos. When I went to install the compnent to the IDE and add it to a form the companent appeared, but it was about the size of a button icon. Any attempt to edit the compnent  via the properties or by moving/expanding the canvas item gave an invalid cast exception. The component also did not show up in the generated code.
http://www.tor-vak.co.uk/ic/invalidcast.JPGis a screen shot
Any ideas
Re: Invalid Cast
Reply #1 - Feb 16th, 2006 at 2:39pm
Yes, the same problem happens here occasionally when we create a new project. To fix it, remove the reference to System.Design.dll, restart VS and load the project again. Now drawing a PocketPlanner instance on the form should work fine.
