Normal Topic Disable Box Creation (Read 1449 times)
Ganesh Muthuvelu
Guest
Feb 20th, 2006 at 1:17pm
I do not want end users to create boxes at run time. Basically, all boxes are created using code and end users should only be able to map the boxes (create arrows).
However, in the flowchart, I see that boxes can be created- if the mouse is dragged on any empty area. How do I disable this feature?
Ganesh
Re: Disable Box Creation
Reply #1 - Feb 20th, 2006 at 1:21pm
Set the flowchart.Behavior property to CreateArrows.
