Normal Topic Remove control points from an arrow (Read 3858 times)
CharlesG
Feb 21st, 2006 at 1:54pm
The flowchart I have is using Polyline arrows, SegmentCount is 1, SnapToAnchor property is set to saOnCreateOrModify.
I allow the user to add multiple controls points to the arrows between boxes by dragging them, however, I also want to provide the functionality where they can just remove all the control points (apart from 2 needed for a 1 segment arrow) by selecting an arrow and choosing a menu option.
Here is the code I have been trying to do this with:
foreach (Arrow arr in this.FlowChartMap.Selection.Arrows)
arr.SegmentCount = 1;
int NoOfControlPoints = arr.ControlPoints.Count;
for (int i = 1; i < (NoOfControlPoints - 1); i++)
arr.ControlPoints.RemoveAt(i);
arr.UpdateFromPoints();
However, the flowchart appears as a huge X when I run this code. How should I be removing the control points?
Charles
Re: Remove control points from an arrow
Reply #1 - Feb 21st, 2006 at 3:11pm
After you set
the ControlPoints collection will contain just two points, you should not remove any points from it. You could just restore the end points positions, e.g.
srcPt = arr.ControlPoints[0];
dstPt = arr.ControlPoints[arr.ControlPoints - 1];
arr.SegmentCount = 1; // that resets the points
arr.ControlPoints[0] = srcPt;
arr.ControlPoints[1] = dstPt;
CharlesG
Reply #2 - Feb 22nd, 2006 at 9:16am
That code works when the arrow has 3 control points. However it doesn't work when the arrow has more than 3 control points, the arrow appears to be disjointed/split after running the code.
Also, setting to SegmentCount = 1 does not change the no. of the control points, the number of these always stays the same.
Any ideas?
Charles.
Reply #3 - Feb 22nd, 2006 at 9:37am
Hi
Are you sure the arrow is a Polyline one ? If the arrow Style is cascading, the control won't let you set less than 2 segments.
CharlesG
Reply #4 - Feb 22nd, 2006 at 2:00pm
Yes it is polyline.
It has originally only one segment and the user can then drag it around to add more.
Charles.
Reply #5 - Feb 22nd, 2006 at 2:58pm
Is by any chance arrow.AutoRoute enabled ? If it's enabled, the control won't let you change the number of segments at all. You might have to set AutoRoute = false temporarily.
CharlesG
Reply #6 - Feb 22nd, 2006 at 3:03pm
Yes that's it !
I set AutoRoute to false and that resolves it.
Thanks a lot,
Charles.
