Normal Topic Layered Layout (Read 1274 times)
Gamesmeister
Layered Layout
Mar 8th, 2006 at 5:46pm
I'm using a Layered Layout within a flowchart, and for some reason it doesn't always draw the nodes as well as it could.
For example, I have a flowchart with 17 tables in it, in 5 layers. The bottom layer has 4 tables that are connected to a matching set of 4 tables in the layer above. For some reason, two of the bottom tables are switched around, so that the arrows connecting them cross over, as per the following:
table1Parent table2Parent
table2Child table1Child
Table1Parent connects to Table1Child, and the same for table2.
Any idea what I can do about this? I'm running version 3.2 - have the drawing algorithms been updated at all for version 4?
Many thanks
Gerry
Re: Layered Layout
Reply #1 - Mar 8th, 2006 at 7:04pm
Could you call SaveToFile on that diagram and send us the file ?
Thank you,
