Normal Topic findGroup (Read 3273 times)
T.Pascal
Guest
findGroup
Mar 16th, 2006 at 6:13am
hi , i've tryied to use the findGroup methode,
as it said , i've tagged the group.
 <Serializable()> Friend Class GroupProps
	  Public groupId As Integer = 0
    End Class
and every times a group is created , i set groupProps.groupId = boxProps.boxId
the only problem i have is to know how to use findGroup methode to find back a group with a specified Id
Re: findGroup
Reply #1 - Mar 16th, 2006 at 7:05am
You can override the Equals method in the GroupProps  class and return true if the IDs are equal. Then when looking for a group, create a new GroupProps instance, set its ID and call FindGroup passing the properties object as argument.
t.Pascal
Guest
Re: findGroup
Reply #2 - Mar 16th, 2006 at 8:19am
hi ,
I've tryed this:
Private Sub fc_MouseMove(ByVal sender As Object, ByVal e As System.Windows.Forms.MouseEventArgs) Handles fc.MouseMove
	  If e.Button = MouseButtons.None Then
		Dim point As New Point(e.X, e.Y)
		Dim mousePos As New PointF
		tboxcreating = False
		mousePos = fc.ClientToDoc(point)
		currentBox = fc.GetNodeAt(mousePos, True, True)
		If Not currentBox Is Nothing Then
		    If currentBox.Shape.Id = "Rectangle" Then
			  fc.Behavior = BehaviorType.CreateBox
			  tboxcreating = True
			  Dim boxprop As boxProps = currentBox.Tag
			  Dim FGroup As New groupProps
			  FGroup.groupId = boxprop.boxId
			  currentGroup = fc.FindGroup(FGroup)
		    Else : fc.Behavior = BehaviorType.FlowChart
		    End If
		End If
	  End If
    End Sub
 Private Sub fc_BoxCreated(ByVal sender As Object, ByVal e As MindFusion.FlowChartX.BoxConfirmArgs) Handles fc.BoxCreating
	  onBoxCreated(e.Box)
	  If e.Box.Shape.Id = "Rectangle" Then
		Dim boxprop As boxProps = e.Box.Tag
		Dim groupProps = New groupProps
		newgroup = fc.CreateGroup(e.Box)
		newgroup.Tag = groupProps
		Dim groupTag As groupProps = newgroup.Tag
		groupTag.groupId = boxprop.boxId
	  End If
	  If tboxcreating = True Then
		currentgroup.AttachToCorner(e.Box, 0)
	  End If
    End Sub
    Private Sub onBoxCreated(ByVal node As Box)
	  Dim props = New boxProps
	  count += 1
	  node.Tag = props
	  Dim boxTag As boxProps = node.Tag
	  boxTag.boxId = count
    End Sub
but it says the currentGroup is null  , so every time i create a box in another one , it return a 'System.NullReferenceException' error.
Re: findGroup
Reply #3 - Mar 16th, 2006 at 9:11am
Have you implemented the Equals method for the properties class ? Anyway, can't you use the MasterGroup or SubordinateGroup properties of the Box to find the related group ?
T.Pascal
Guest
Re: findGroup
Reply #4 - Mar 16th, 2006 at 9:27am
hi ,
you right , i've try
currentGroup = currentBox.SubordinateGroup
and it works perfectly
thanx alot Stoyan
T.Pascal
Guest
Re: findGroup
Reply #5 - Mar 30th, 2006 at 5:41am
hi ,
like findGroup , i don't know how to use findBox.
the tag is composed by several item, and one of them is unique for each box (boxId as integer) how could i find a box wich i only know the boxId and nothing else ?
Re: findGroup
Reply #6 - Mar 30th, 2006 at 9:01am
You can implement an Equals method in the box tag class, so it returns true if two tag objects contain the same unique id. Then pass to the FindBox method a tag instance whose id is set, and you will get the box whose tag contains the same id.
Or otherwise just do a foreach loop and compare the box.Tag.Id with the one you are looking for, that won't be slower than FindBox.
