Normal Topic customize tooltip of shapes (Read 2111 times)
T.Pascal
Guest
Mar 17th, 2006 at 11:22am
hi , is it possible to customize the tool tip of the predefined shape of flowchart.net
Re: customize tooltip of shapes
Reply #1 - Mar 17th, 2006 at 12:26pm
Do you mean the tooltips displayed for buttons in the shape toolbar ?
T.Pascal
Guest
Reply #2 - Mar 17th, 2006 at 12:35pm
yes, it is
Reply #3 - Mar 17th, 2006 at 1:00pm
It seems possible, try using the Buttons collection to access the toolbar buttons and set their ToolTipText property. The buttons are recreated if you change the shape filter, so you must reassign the tooltips each time you add or remove shapes.
