Normal Topic Pathfinding (Read 1803 times)
Hallo.Amt
Pathfinding
Mar 28th, 2006 at 12:00pm
Hi Stoyo,
I have two other problems now Sad . They are both about the pathfinding. The first is quite simple (hopefully) it's just, that if you use Table.createRelation() to create an arrow it seems not to appear in table.IncomingArrows. The other one is if there is a possibility to trace a path without caring about the directions of the arrows.
Thanks Justus
Re: Pathfinding
Reply #1 - Mar 28th, 2006 at 12:13pm
Hi Justus,
If an arrow links to a row, it can be accessed via the Table.Row[x].IncomingArrows or Table.Row[x].OutgoingArrows.
The PathFinder in the ActiveX version of this control has an option to search for non-directed paths, I guess it will be easy to port that to FlowChart.NET.
Hallo.Amt
Re: Pathfinding
Reply #2 - Mar 28th, 2006 at 12:29pm
That feature would be great.
Justus
