Normal Topic Scollbars (Read 1272 times)
Dana Beck
Guest
Scollbars
Apr 5th, 2006 at 11:38am
After populating my FlowChart with "Boxes" created from data in database I call.
1. TreeLayout1.Arrange(FlowChart1)
2. FlowChart1.AutoSizeDoc = MindFusion.FlowChartX.AutoSize.AllDirections
The result is that half the chart is of the right of the screen and I can't scroll there.
Am I doing something wrong or is this a bug? As I understand it the "AutoSizeDoc" method should have sorted this out.
Re: Scollbars
Reply #1 - Apr 5th, 2006 at 12:32pm
After adding or arranging boxes programmatically, call FitSizeToObjects. AutoSizeDoc resizes the document only when users draw or drag objects, but not when creating or modifying objects via the API. It's like that because calculating the document size could slow down the creation of objects, say if you create 1000 boxes in a loop.
