Normal Topic Crash inside LoadFromString (Read 3695 times)
jvaldehita
Apr 6th, 2006 at 9:38am
Hi.
I´m having problems when loading a diagram that´s been saved to a string.
It´s a big graph (around 130 boxes, 1000 arrows).
I´m using flowchartx from Visual Studio 2003, using unmanaged C++.
I´ve been able to create a graph (m_GraphView) and I get a crash inside LoadFromString using the following code:
CString flowChartSavedString = m_GraphView.SaveToString(FALSE);
m_GraphView.LoadFromString(flowChartSavedString);
I´ve been able to save the contents of the returned string to disk, and will email it if needed to fix the bug.
Re: Crash inside LoadFromString
Reply #1 - Apr 6th, 2006 at 3:36pm
We have seen this problem before. There is a bug in the  MFC CString to BSTR conversion, it crashes with very large strings. We worked around that by using the raw IFlowChart interface and passing the BSTR data directly to the LoadFromString method, without converting to/from CString. Include the flowchart.h file installed with FlowChartX (but not the MFC wrapper one). That will give you the definition of the IFlowChart interface and IID_IFlowChart interface ID. Query for that interface and use its SaveToString/LoadFromString methods directly.
jvaldehita
Reply #2 - Apr 7th, 2006 at 8:02am
Stoyan,
thanks for your quick reply.
Done as you said, works OK.
I´ve sought any indication of this issue in the documentation. I´ve found none. If it is not mentioned there, it should be (and prominently). It would be a real time saver.
Thanks again for your quick response.
Jorge.
Reply #3 - Apr 7th, 2006 at 9:30am
Yes, I guess we should document that. It will be done in the next version of the help file.
