Normal Topic Visio Exporter: No such interface supported (Read 7231 times)
Bas
Apr 18th, 2006 at 4:18am
This morning I installed the Visio Exporter control in Delphi 2005. When calling ExportVDX(myFlowChartXCtrl, 'c:\test.vdx') an EOleException is raised stating "No such interface supported".
I checked if FcxVisioExport.vxt is in the same path as the executable, and it is.
What could be causing the problem here, and how can I fix this?
Re: Visio Exporter: No such interface supported
Reply #1 - Apr 18th, 2006 at 7:09am
VisioExporter works only with the FlowChartX Pro edition. That error might happen if you try to use it with the standard edition of the control.
Bas
Reply #2 - Apr 18th, 2006 at 7:22am
I checked the type library, and it says (amongst other things):
// PASTLWTR : 1.2
// File generated on 14.4.2006 7:05:43 from Type Library described below.
// Type Lib: C:\WINDOWS\system32\FlowChartPro.dll (1)
// LIBID: {69ECBBD3-5C2A-4A84-ABEC-23937DBF1B54}
// LCID: 0
So I am using the pro version as far as I can tell. I do however have both versions installed on the same machine.
Ill try unregister the non-pro version, see if that makes a difference.
Bas
Reply #3 - Apr 18th, 2006 at 7:27am
I uninstalled the non-pro version, and checked that the .dll file was removed.
Same exception however..
Reply #4 - Apr 18th, 2006 at 7:53am
This isthe only code in VisioExporter.Export() that can throw the exception
// QI for IFlowChart interface of passed DISPATCH
hr = lpFlowChartX->QueryInterface( __uuidof(FXChart::IFlowChart),(void**) &pChart);
if FAILED(hr)
  throw _com_error(hr);
If the Delphi IDispatch wrapper for the FlowChart class does not implement the raw IFlowChart interface, the QueryInterface call above will fail. If any member of the wrapper class gives you access to the internal raw IFlowChart or IUnknown pointer, try passing it to the exporter instead of the Delphi object.
Bas
Reply #5 - Apr 18th, 2006 at 8:46am
I passed the .DefaultInterface property as the first parameter which returns an IFlowChart..
.. et voila Grin
I dont understand why the queryInterface fails becuase in the TLB IFlowchart is defined like:
IFlowChart = interface(IDispatch)
If you want the generated TLB to play with let me know, and I can email it. Might be interresting.
Thanks for the solution!
Bas
Reply #6 - Apr 18th, 2006 at 9:07am
Btw, the same goes for the Visio importer, ofcourse.
Reply #7 - Apr 18th, 2006 at 10:10am
Ok, that's great. The Export method takes an IDispatch pointer as argument and Delphi might pass an internal IDispatch implementation object that doesn't actually implement IFlowChart.
I don't know why Export doesn't take an IFlowChart argument. The Delphi wrapper object would probably work nice then.
