Normal Topic Dynamically creating arrows by anchor points (Read 1194 times)
FusionUser
Apr 18th, 2006 at 5:11pm
In my project I need to create tables with anchor points and arrows that connect the anochor points dynamically.  I was able to create the tables with anchor point successfully and I have problem creating the arrows from the source anchor point to the destination anchor point.  I tried to use the CreateArrow method for the chart control but I couldn't see any overloaded version that uses SourceTable, SourceAnchorpoint, DestinationTable, DestinationAnchopoint.
Do you have know what is the best method to acheive this?
Re: Dynamically creating arrows by anchor points
Reply #1 - Apr 19th, 2006 at 5:35am
After creating an arrow, set its OrgnAnchor and DestAnchor properties. They specify the indices of points in the table.AnchorPattern.
