Normal Topic Items falling off the calendar (Read 4690 times)
Damian
Guest
Apr 20th, 2006 at 8:00am
If i drag/move an item around the calendar ots fine but if i drag it outside the cells i.e. past the last hour and unclick the mouse the item just disappears - where dows it go exactly or how can i stop a user doing this! I want them to be able to move stuff around but not accidentally throw it away.
If a drag it off then back again its still there.
Re: Items falling off the calendar
Reply #1 - Apr 20th, 2006 at 9:21am
You can handle the ItemModifying event end check that the new start and end time of the modified item stay within the displaye time range.
Damian
Guest
Reply #2 - Apr 20th, 2006 at 6:09pm
Thats almost sorted it - it goes a bit funny when at the header when the all day event kicks in.
My code is:
     int start = 0;
     int cell = 0;
     start += e.NewStartTime.Hour * 60;
     start += e.NewStartTime.Minute;
     cell += cal.TimetableSettings.CellTime.Hours * 60;
     cell += cal.TimetableSettings.CellTime.Minutes;
     if (start < cal.TimetableSettings.StartTime)
       e.Confirm = false;
     if (start  > (cal.TimetableSettings.EndTime - cell))
       e.Confirm = false;
If you try that code you will see what i mean about it going funny at the top - it disappears and you get the dots...  Im in timetable setting.
Can you get rid of the all day events? I want them to be honest.  Ive tried setting max alldayevents to 0 but min is 1.
Damian
Guest
Reply #3 - Apr 20th, 2006 at 6:25pm
What i mean by funny is if you clickan item and drag it up the day column, over the all day event header and off the control and then back down the column you get the dots in the drop down control in the all day event header and the item your dragging disappears.  When you unclick the mouse it comes back again but why does it disappear?
I would really like to remove alldayevents too.
Reply #4 - Apr 21st, 2006 at 4:28am
What happens when you set 'cal.TimetableSettings.ShowDayHeader = State.Disabled;' ?
Damian
Guest
Reply #5 - Apr 23rd, 2006 at 7:30pm
Yep - that works.  You may want to check it out for people using the header though. Think theres a bug there.
