Normal Topic DB design (Read 4477 times)
filip.geens
DB design
May 10th, 2006 at 5:09am
It should be nice to have a checkbox for each field in the database table-designer.  This allows the use of certain fields of that specific table.
Re: DB design
Reply #1 - May 10th, 2006 at 8:38am
I believe you can implement that easy like this:
- allocate one column for the check-boxes
- handle the CellClicked event to toggle the row state
- and custom-draw the cells by calling e.Graphics.DrawImage in the DrawCell handler
filip.geens
Re: DB design
Reply #2 - May 10th, 2006 at 9:16am
I have already done that, but I think it is a nice feature to have it onboard  Grin
Re: DB design
Reply #3 - May 10th, 2006 at 10:33am
Probably we can implement something more general, like the ControlHost nodes functionality, but in table cells, because people will start requesting other controls too when they see the check boxes Wink
filip.geens
Re: DB design
Reply #4 - May 10th, 2006 at 10:57am
Looks like a very efficient  solution.
