Normal Topic asp.net - hyperlink (Read 3827 times)
pengwin
U2 UniVerse | SB+
asp.net - hyperlink
May 16th, 2006 at 6:41am
is there a way to specify the target detail when a box has a hyperlink (asp.net)
<AREA SHAPE="RECT" COORDS="261,1152,336,1227"
HREF="www.mypage.com" TARGET="_blank" ALT="">
with the target as built by default the hyperlink opens in a new browser window - is there a way to specify an alternate target detail for the box's hyperlink?
Many thanks.
Re: asp.net - hyperlink
Reply #1 - May 16th, 2006 at 7:16am
Yes, that's possible. Set the HtmlBuilder.LinkTarget property to "_self" or to the name of the frame where you need the link to open.
pengwin
U2 UniVerse | SB+
Reply #2 - May 16th, 2006 at 8:52am
sorry for this next "stupid" question, but is there a small sample of where HtmlBuilder.LinkTarget attaches to, so that I can mod the property as per the answer?
Many thanks.
pengwin
U2 UniVerse | SB+
Reply #3 - May 16th, 2006 at 9:28am
i've added
Dim hb As New HtmlBuilder(fc)
hb.LinkTarget = "_self"
and "watched" hb , it's LinkTarget is "self"
I add the box with :
im node As Box = fc.CreateBox(xVal, yVal, xBoxSize, yBoxSize)
	  node.Text = strBoxText
	  node.TextFormat.LineAlignment = StringAlignment.Center
	  'node.FitSizeToPicture()
	  node.Transparent = False
	  node.FrameColor = boxFrameColour.Black
	  node.FillColor = boxColour
	  node.TextColor = boxTextColour
	  node.HyperLink = "www.mypage.com"
but the area is still specified
is there something i'm doing wrong with the order?
Reply #4 - May 16th, 2006 at 9:39am
Actually "_self" is the default value. Could you check whether "_blank" isn't set somewhere later in the code ?
pengwin
U2 UniVerse | SB+
Reply #5 - May 16th, 2006 at 9:46am
Embarrassed Embarrassed Embarrassed <--- blushes
doh! sorry 'bout that one, rechecked "higher" up in the code and found it !
fc = Me.Session.Item("fcx")
	  If Not fc Is Nothing Then
		'hb.LinkTarget = "_blank"
		Return hb.CreateImageMap("map1")
	  End If
thanks soooo much for the help (even with my stoooopid question) - but then again some of the gr8 discoveries were from mistakes Wink .. here's hoping! Thanks again. Smiley
Reply #6 - May 16th, 2006 at 9:53am
way to go Wink
