Normal Topic Navigation Buttons on Timetable (Read 5152 times)
Philip
Guest
May 18th, 2006 at 5:44pm
I am evaluating your control, and it looks great, but I am running into some minor problems.
It seems that when you enable the Navigation Buttons for the Timetable that they don't call the VisibleDateChanged event when they are clicked like they do in the other views.
Also, in the properties window of the designer the popup dialog for the ItemChangeReferenceKey won't save the setting.
Thanks.
Re: Navigation Buttons on Timetable
Reply #1 - May 19th, 2006 at 4:49am
You are correct. We will fix these issues as soon as possible and send you the new version.
Thank you for your feedback.
Reply #2 - May 19th, 2006 at 7:57am
Here you can try a new prerelease version of Planner.NET 3.2:
https://mindfusion.org/_temp/_Planner.NET_32pre_trial.zip
(This is a temporary url and might not work in the future.)
All the issues should have been taken care of. Please, try it and let me know whether everything is ok.
philip
Guest
Reply #3 - May 19th, 2006 at 4:02pm
I keep getting this error with the files you posted:
'The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040)'
The reference properties show 3.2 and the calendar "About" shows 3.2 as well, it just won't compile.  This is on VS2005.  Any ideas?
Philip
Guest
Reply #4 - May 19th, 2006 at 4:22pm
Okay, I got it working, I had to delete the license file.  The VisibleDateChanged event is firing now, but the ItemChangeReferenceKey property window still doesn't work.  This is in VS2005.
Reply #5 - May 22nd, 2006 at 4:17am
Yes, you are correct. It seems that the built-in design-time editor for the Keys class in VS 2005 does not allow modifier keys only (it allows only combinations). We will try to replace the default editor with a custom one. Thanks for your feedback.
Reply #6 - May 22nd, 2006 at 7:57am
Here you can download the lates (hopefully fixed) version of Planner.NET:
https://mindfusion.org/_temp/_Planner.NET_32pre_trial2.zip
The default design-time editor for the Keys class has been substituted and should now work as expected.
