Normal Topic Horizontal limits (Read 1618 times)
Kalex
Horizontal limits
May 18th, 2006 at 7:33pm
Is there a limit to the horizontal size of a flowchart?  I am using a flow chart inside a ruler component and after creating a table, I can only drag the table so far to the right.  However, if I use the rulers click and drag guideline, then I can move the table all the way to the right.  Also, I can not get the horizontal scroll bars to show.
Thanks for any input on this.
Ken
Ken
Re: Horizontal limits
Reply #1 - May 19th, 2006 at 5:02am
The default document size is RectangleF(0, 0, 210, 297) millimeters (A4), and users are not allowed to drag objects outside it. You can enable the AutoSizeDoc property to have the document resize automatically when objects are dragged towards its edges, that will also increase the scrollbar ranges. Or set DocExtents to a larger value if you don't want to enable automatic resizing.
Kalex
Reply #2 - May 19th, 2006 at 6:23pm
Thanks, that did the trick.
Ken
