Normal Topic PrintPreviewEx Landscape (Read 1978 times)
Kalex
Jun 7th, 2006 at 4:25pm
Clicking the Landscape/Portrait button does not switch the paper orientation.
Maybe I'm just not sure how to use this feature.  Could someone shed some light.  Thanks.
Ken
Re: PrintPreviewEx Landscape
Reply #1 - Jun 7th, 2006 at 5:04pm
Does that happen with the .NET 2 version ? We've recently found that happens on some systems when using the .NET 2 runtime. The problem will be fixed in the next release.
If you have the flowchart.net source code, add a call to the PrintPreviewControl.InvalidatePreview method in the landscape button handler and rebuild the project - that should fix the problem.
Kalex
Reply #2 - Jun 7th, 2006 at 6:04pm
Yes, .net ver 2.
Do you have an ETA on the next release?
Ken
Online
Reply #3 - Jun 8th, 2006 at 8:17am
We are releasing version 4.2 by the end of June.
