Normal Topic Wrapper Control Example (Read 4211 times)
alfadata
Jun 12th, 2006 at 1:41pm
Does anyone have an example wrapper control that works with JavaScript / Client-Side events? We wish to use the BosDeleting event however are not having great success.
Re: Wrapper Control Example
Reply #1 - Jun 12th, 2006 at 1:54pm
It might be easier to set KbdActive = false and process the KeyDown event yourself instead of creating a wrapper control.
alfadata
Reply #2 - Jun 12th, 2006 at 2:11pm
This would only capture the fact the keyboard was used. We are looking to have control of the actual FlowChart events and elements on the client-side prior to the postback.
Reply #3 - Jun 12th, 2006 at 2:38pm
Are you talking about the ActiveX version ? You can handle most of the FlowChartX events from JavaScript; only the validation events that have output parameters cannot be handled.
alfadata
Reply #4 - Jun 12th, 2006 at 3:23pm
We are using the .NET control. We are trying to control what boxes the user has the ability to delete and potentially control what boxes can be connected to each other.
Reply #5 - Jun 12th, 2006 at 6:08pm
Ok, I've played a bit with this and created the following wrapper ontrol:
[code]
namespace FcnetWrap
/// <summary>
/// Summary description for FcnetHandler.
/// </summary>
public class FcnetHandler : System.Windows.Forms.UserControl
/// <summary>
/// Required designer variable.
/// </summary>
private System.ComponentModel.Container components = null;
public FcnetHandler()
// This call is required by the Windows.Forms Form Designer.
InitializeComponent();
// TODO: Add any initialization after the InitializeComponent call
flowChart1.BoxCreating += new BoxConfirmation(flowChart_BoxCreating);
/// <summary>
/// Clean up any resources being used.
/// </summary>
protected override void Dispose( bool disposing )
if( disposing )
if(components != null)
components.Dispose();
base.Dispose( disposing );
#region Component Designer generated code
#endregion
private MindFusion.FlowChartX.FlowChart flowChart1;
private void flowChart_BoxCreating(object sender, BoxConfirmArgs e)
MessageBox.Show("BoxCreating raised");
[/code]
Reply #6 - Jun 12th, 2006 at 6:20pm
Now adding this
<OBJECT id=fch height=100 width=100 classid=FcnetWrap.dll#FcnetWrap.FcnetHandler VIEWASTEXT>
</OBJECT>
to the ClientSvr example and removing the original OBJECt tag referring to FlowChart.NET.dll seems to work fine. It seems the .NET loader manages to find and download FlowChart.NET dll when the FcnetWrap.dll requests it. I had deleted all files from the "Temporary internet files" folder, and used
gacutil /cdl
to remove everything from the GAC download cache before trying this. The wrapper control loads fine and displays the message box when the CreatingBox event is raised.
Reply #7 - Jun 12th, 2006 at 6:26pm
As for handling events from JavaScript, you might have to declare a COM interface describing the events you are interested in and implementing it in the wrapper control. Then when a FlowChart.NET event is raised, the wrapper control should fire the corresponding COM event. An example is available here:
http://msdn.microsoft.com/msdnmag/issues/02/01/UserCtrl/default.aspx
