Normal Topic Themes (Read 4259 times)
Martin
Themes
Jun 15th, 2006 at 6:30am
Is there any way to define your own themes for pocket planner? Alternatively any other way to change the color of the timeline?
Re: Themes
Reply #1 - Jun 15th, 2006 at 6:50am
It is not currently possible to define your own themes in PocketPlanner. Regardless, almost every single visual aspect of the control can be customized, including the timeline. If you refer to the timeline in the Timetable view, then you can change its fill color by settings the Calendar.TimetableSettings.TimelineStyle.HeaderBrush property. The following example sets the timeline color to Blue:
calendar.TimetableSettings.TimelineStyle.HeaderBrush =
   new MindFusion.Drawing.SolidBrush(Color.Blue);
Martin
Re: Themes
Reply #2 - Jun 15th, 2006 at 7:04am
thnx! Just did not realize that HeaderBrush was the setting Smiley
Martin
Re: Themes
Reply #3 - Jun 15th, 2006 at 7:39am
One last question.. where do you set the fill-color for a selected cell in timetableview?
Re: Themes
Reply #4 - Jun 15th, 2006 at 9:28am
Use the Calendar.Selection.SelectedElementsStyle.Brush property.
