Normal Topic Render different images at different zoom levels? (Read 3476 times)
chadbr
Jun 21st, 2006 at 7:33pm
Is there any way to have the control render different images at different zoom levels?
Or render vector graphics instead of bitmap graphics?
We have great looking graphics for standard zoom level - but when you zoom in or out too far the bitmaps become distorted or jagged.
Thanks for any suggestions...
Chad
Re: Render different images at different zoom leve
Reply #1 - Jun 22nd, 2006 at 5:44am
Handle the ZoomFactorChanged event and load the images corresponding to the new ZoomFactor value, or try using WMF images to render vector graphics.
chadbr
Reply #2 - Jun 22nd, 2006 at 12:41pm
We tried WMF images a while back - they just got converted to bitmaps.
We'll give the ZoomFactorChanged a try...
Are there any plans to handle any other formats?
Thanks, Chad
Reply #3 - Jun 22nd, 2006 at 3:34pm
The metafiles should work nice as vector graphics the first time you load them. I think the WMF images might be converted to bitmaps if you save a diagram and reload it back if there isn't a WMF image encoder provided with .NET.
FlowChart.NET does not encode or decode images by itself, it relies on the .NET GDI+ encoders and decoders. If FlowChart.NET cannot encode an image back to the original format of the image, it will default to PNG.
As a work-around you might reload the metafiles after loading a diagram. Or instead of setting the Box.Image property, set the ShapeTemplate.Image - that will avoid saving/loading the images altogether.
