Normal Topic Arrow Selection and Collapse/Expand Functionality (Read 1726 times)
Vidhya Ganesan
Guest
Jun 21st, 2006 at 9:03pm
I came across Flowchart.net and am using trial version. We have 2 clarifications.
1)  Arrow Selection :
I have a Box A.  On top of it i draw two boxes B and C and attach both the boxes to A by using AttachTo API.  I draw an arrow to connect boxes B & C. When i draw the arrow, i am able to select it. But once i select box B/C and then click on the arrow, box A gets selected instead of the arrow. I am not able to select the arrow. Let me know if there is a way to make the arrow selectable.
2) Expand/Collapse:
I have two boxes A and B. A is connected to B(A--> B) . "A" contains few more boxes inside it.  I have marked A as expandable.
On Expand/Collapse of "A", i try to show/hide all the boxes present inside "A". I dont want B to get collapsed when i click on "A".  How can i avoid collapsing "B"?
Regards
Vidhya Ganesan
Re: Arrow Selection and Collapse/Expand Functional
Reply #1 - Jun 22nd, 2006 at 5:58am
arrow selection:  set HitTestPriority to ZOrder
expand/collapse: try handling the TreeCollapsed event and in the handler set B.Visible = true, and if there are some boxes connected to B call B.Expand() .
Vidhya Ganesan
Guest
Reply #2 - Jun 22nd, 2006 at 10:49pm
Thanks.
Arrow Selection is working fine.
