Normal Topic Help with custom Cursors (Read 2440 times)
Anthony Silva
Guest
Jun 29th, 2006 at 4:17pm
I'm trying to do a basic panning implementation a la acrobat reader where you click to grab and then drag to pan around in the document. I haven't started the panning code, but I don't anticipate any problems based on the API docs.
However, I AM having a problem with setting the mouse cursor to something other than the standard pointer. I have a MouseMove handler that I'm setting the cursor to my custom cursor every tick if the mouse button is down, but it seems to be getting overwritten by FlowChart.NET.
I read about the CustomBehavior stuff, but I'm a little unclear about how to create my own and how does it affect the standard one that I select in the forms designer. Basically, I would just want to implement the SetMouseCursor function and leave the others alone, but it looks like I can't.
Or maybe there's an easier way entirely...any help would be greatly appreciated!
Anthony
Re: Help with custom Cursors
Reply #1 - Jun 29th, 2006 at 4:51pm
Panning is already supported, but you must hold the ALT key down while dragging to pan around. In the ActiveX version there is a pan- Behavior which lets you pan without usnig ALT, we can port that to FlowChart.NET too in a few days.
Anthony Silva
Guest
Reply #2 - Jun 29th, 2006 at 6:22pm
>> "Panning is already supported..."
Good to know.  Smiley However, I'm going to continue coding my custom panning because I want to pan with the middle mouse button (similar to IE and some other programs). If panning capability is customizable in the future that'd be great, tho, too.
I've found a way around the cursor issue as well, I just temporary set CurPointer to the new cursor and then set it to Cursors.Default when the button is released. Under the hood, it's not exactly what I want, but from the user's perspective, you can't tell the difference.  Cheesy
Anthony Silva
Guest
Reply #3 - Jun 29th, 2006 at 8:02pm
Sorry all - I just realized I posted this in the FlowChartX forum. It was intended for the .NET'ers. Wink
Reply #4 - Jun 30th, 2006 at 5:42am
* moved from FlowChartX/Discussion *
Reply #5 - Jun 30th, 2006 at 5:54am
We are going to add to the next version a property that maps the middle button to panning, and possibly other functions. But feel free to implement your own panning if you want  Wink
