Normal Topic the tag property for xml.writer (Read 1197 times)
alexdoan
Jul 2nd, 2006 at 10:30am
I need a vb.net example how to serialize and deserialize the tag property.
I am having problems because the serialize and deserialize is not firing.
i added:
AddHandler writer.SerializeTag, AddressOf writer_SerializeTag
but the writer is not firing this event.
please give me code example
Re: the tag property for xml.writer
Reply #1 - Jul 3rd, 2006 at 5:40am
The event if fired only if some item's Tag is set, e.g.:
Private Sub fc_InitializeBox(ByVal sender As Object, ByVal e As MindFusion.FlowChartX.BoxEventArgs) Handles fc.InitializeBox
e.Box.Tag = fc.Boxes.Count
End Sub
Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
Dim xw As New XmlWriter(fc)
AddHandler xw.SerializeTag, AddressOf WriteTag
xw.Options.CustomTagSerialization = False
xw.Write("C:\test.xml")
End Sub
Private Sub WriteTag(ByVal sender As Object, ByVal e As MindFusion.FlowChartX.Xml.SerializeTagArgs)
If TypeOf e.Object Is Box Then
Dim b As Box = e.Object
e.Representation = b.Tag.ToString()
End If
End Sub
