Normal Topic Z order (Read 1183 times)
Guest
Guest
Z order
Jul 12th, 2006 at 4:32pm
Do flowchart support creating node with Z order and the abilities to hide and show Z order (level) nodes?
Re: Z order
Reply #1 - Jul 13th, 2006 at 4:11am
Items have a ZIndex property that lets you control the Z order. Nodes can be hidden by setting their Visible property = false. There is no intrinsic support for layers are not supported, if that 's what you need. You could implement some sort of layers using the ZIndex, Locked and Visible properties of items.
