Normal Topic Inserting pointcontrol into the right place   (Read 1036 times)
qqterry123
Jul 16th, 2006 at 7:54am
here is the situation i am facing: when i created arrow between 2 nodes and i want to create a pointcontrol when the user clicked on the arrow that is between 2 controlpoints how do it find out the index position of these 2 pointcontrols in the arrow.pointcontrols property, so i can insert the new pointcontrol into the correct index in the arrow.pointcontrols property?
Or there are another approach to achieve this?
Thanks alot in advance
Re: Inserting pointcontrol into the right place
Reply #1 - Jul 17th, 2006 at 6:41am
One of the overloaded GetArrowAt methods returns the segment index through a 'ref' parameter.
You might set AllowSplitArrows = true to let users insert new control points by clicking and dragging segment points.
