Normal Topic Calendar control with .NET 2.0 (Read 4390 times)
rfeuer
Jul 17th, 2006 at 6:22pm
I am trying to test your sample apps using VS 2005 / .net 2.0. When I  create a new form and drop your calendar control on the form, I get a license exception stating: " Couldn't get design-tim license for MindFusion.Scheduling.WinForms.Calendar.... This is a trial version. BTW I am able to do the same thing using VS 2003 with no problems. Any ideas?
Rick
Re: Calendar control with .NET 2.0
Reply #1 - Jul 18th, 2006 at 4:38am
Cannot really reproduce this problem here. Please ensure that you install the Planner control on the machine with VS 2005 if it is on a different PC. Simply copying the dll won't do.
Reply #2 - Jul 18th, 2006 at 10:52am
Do you, by any chance, use your MS Visual Studio 2005 on a 64-bit PC under WinXP x64 or Win2003 x64?
rfeuer
Reply #3 - Jul 18th, 2006 at 2:41pm
No I am using a 32bit machine
Reply #4 - Jul 18th, 2006 at 5:59pm
Could you open the project's licenses.licx file and see if there is a public key token at the end of the Planner.NET line ? If there is one - replace it with 'null' so it reads PublicKeyToken=null. The .NET 1.1 and .NET 2.0 versions of Planner.NET are signed with different strong name keys, so that might cause problems when changing the reference from one version of the dll to the other one.
rfeuer
Reply #5 - Jul 18th, 2006 at 7:00pm
The problem was due to the fact that I did not install the planner control on the new machine, instead I just copied the dll's, thinking that would work. Everything is working fine now.
Thanks for you help
R
