Normal Topic Recurring appts < 1 minute in length (Read 3607 times)
ncsbrandon
Jul 19th, 2006 at 3:18pm
When i create a daily recurring appointment that's less than 1 minute in length, the repearting occurances don't have the correct lengths in the timetable.  They simply show the start and stop times as being the same.  The original appointment however displays correctly.
Once i make the appointment greater than a minute in length, the repeating occurances are correct.
-Brandon
Re: Recurring appts < 1 minute in length
Reply #1 - Jul 20th, 2006 at 4:45am
Correct, recurrence can be specified with minute precision, thus item shorter than 1 minute cannot be recurred properly. Also, recurrence cannot be applied to items longer than 1 day.
We will revise the way recurrence works in the next release, so it is usable with no restrictions.
ncsbrandon
Reply #2 - Jul 20th, 2006 at 1:46pm
ok, thanks.  Do you have any information about the date of the next release?
Also, about recurrance, can you add support for hourly recurrance?
-Brandon
Reply #3 - Jul 21st, 2006 at 4:55am
The exact date of the release is not yet known, but we will post a new thread on the forum when the beta is available. This is likely to happen until the end of August. As for the hourly recurrence, it all depends on whether there is enough time to fit it in the schedule.
